AutoAttendant Redundancy for Unity in SRST
Dec 15th, 2009
I'm trying to acheive redundancy for AA configured in Unity in a Centralised UCM 7.x environment for a remote site in SRST using TLC script, the solution works fine in MGCP environment but I'm trying to acheive it utilizing H323 as the link is CAS R2 and not PRI, the problem is that the aa number does not hunt for the VoIP dial-peer and always hunts for the pots dial-peer because of the "incoming called number" and "service aa" under the pots, is there away that we can acheive this?
Jonathan Schulenberg Tue, 12/15/2009 - 10:53
Change the preference on your dial peers. Give your VoIP dial peer a preference 0 and the POTS dial peer a preference 1 for example.
elnel Tue, 12/15/2009 - 11:07
Thank you for your reply, but I already tried this and it still hunts to the pots dial-peer a snapshot of the config is as follows :
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 10 voip
preference 0
incoming called-number [Unity AA Number]
destination-pattern [Unity AA Number]
session target ipv4:[UCM IP Address]
codec g711ulaw
no vad
ip qos dscp cs3 signalling
dial-peer voice 100 pots
preference 1
incoming called-number [TLC AA Number]
service autoatt
destination-pattern [TLC AA Number]
port 1/0/0:15
where [Unity AA Number] = [TLC AA Number]
and still the pots gets invoked prior to the voip if I shut down the pots or take incoming called-number for it it goes to unity
