Does LMS3.0 support 3120 HP Enclosure Switch package.
Answered Question
Dec 15th, 2009
Or do I need to wait for LMS 3.2 ?
Correct Answer by Joe Clarke about 7 years 6 months ago
You really need to download all available device packages for RME 4.1.1.  You will also need to install the latest version of the Common Services MDF (1.36).  It's best to do all of this through the GUI.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 12/15/2009 - 10:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the sysObjectID of this device?
kathegaj2 Tue, 12/15/2009 - 10:45
L-Nath-9-ian
Can you tell me how to obtain that information so I may inform you?
(((You know I am a groupie))) lol
Joe Clarke Tue, 12/15/2009 - 10:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can use the SNMP Walk utility in Device Center to walk the starting OID of sysObjectID.
kathegaj2 Tue, 12/15/2009 - 10:54
Okay I am confused. I can't add the device to DCR because I don't have a package to support it. Should I just add it as som
ething else, let RME find out that it is a conflict and then walk it?
Joe Clarke Tue, 12/15/2009 - 10:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can just type any IP address into the Device Center device selector (e.g. 1.1.1.1).  Then launch the SNMP Walk tool, and enter the IP of the device in question.
kathegaj2 Tue, 12/15/2009 - 11:08
RFC1213-MIB::sysObjectID.0 = OID: CISCO-SMI::ciscoProducts.948
Joe Clarke Tue, 12/15/2009 - 11:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This switch is support in RME 4.1.1 (part of LMS 3.0.1) in CBS3000 package version 4.2.
kathegaj2 Tue, 12/15/2009 - 11:19
I am running 4.1.1 and can find
1.3.6.1.4.1.9.1.748Catalyst Blade Switch 3020 for HPCBS30004.1
Attempting download now...
Thank you so much! =-)
kathegaj2 Tue, 12/15/2009 - 12:09
GAH!
To install the Cisco Catalyst Blade Switch 3000 Series Package, you must install the following dependent packages:
SharedSwimIOS.RME41.v2-2-6.zip
LibSwim.RME41.v2-2-4.zip
SharedDcmaIOS.RME41.v2-1-2.zip
so when I go to install CBS3000 it is saying a dependent package needs to be installed, when I attempt to install the requested dependent zip it says it is already installed???
D:\Program Files\CSCOpx\bin> PSUCli.bat -p rme -install -src c:\psu_download\rme
CBS3000
Services might be restarted, as a result of install operation
Would you like to continue ? ( Press y or n )
y
Proceeding with install..
Loaded psu.properties..
INFO: Installing for rme
Locking the package repository...
got all packages Repository
Checking Dependencies...
WARNING: CBS3000(4.2):Consistency check failed for base package SharedInventoryC
atIOS
There are no Packages to be installed
Released the Lock...
No package(s) to install for Resource Manager Essentials
SharedInventoryCatIOS
y
WARNING: SharedInventoryCatIOS(2.1.1):Version 2.1.1 already installed
SharedSwim2900XL.RME41.v2-0-3.zip
LibCommon.RME41.v2-2-4.zip
LibInventory.RME41.v2-2-4.zip
SharedInventoryCatIOS.RME41.v2-1-2.zip
Correct Answer
Joe Clarke Tue, 12/15/2009 - 12:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
