dustinsuko Tue, 12/15/2009 - 12:17
MARS is telling you that it cannot log into the FWSM with the provided information/credentials.
Make sure the supplied login credentials are correct.
Make sure MARS has access to and is allowed (through acls) to log into the FWSM.
This link just shows the basic setup...you probobly already seen it.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/device/configuration/guide/cfgFwall.html#wpmkr370659
Dustin
Parminder Sian Tue, 12/15/2009 - 22:48
  • Bronze, 100 points or more
Just regenerate the key on device as MARS is expecting a 1024-bit or higher key.
Zeroize the key and generate a 1024-bit key:
config term
crypto key zeroize rsa
crypto key generate rsa general-keys modulus 1024
Hope this resolves your issue.
Parminder Sian
