question about CDR file accounting...
Dec 15th, 2009
If you use the flash as a secondary ftp store,and the primary ftp fails, the cdr files are going to be store on your flash until it gets full. so:
- There is no automatic or configurable way to return to write on primary ftp? The documentation says that you manually have to use the command file-acct reset to do that.
- Is there an issue if the flash became full? will it affect the normal behaviour of the router? or the only complication will be that cdr will be lost?
TIA
Andres Pasten Calzada
Adexus S.A.
