UC520 call waiting
Answered Question
how do you set-up call waiting on a UC520 with 7975G phones.  The line type I have set to dual and the most phones are shared extentions between two phones.  Right now when a second call comes in on a SIP DID it goes straight to the PMB.  How to you set-up call waiting.  Everythign I have read says it should be enabled by default ,  yet,  for me,,  not so much!
Thanks  again
Correct Answer by Paolo Bevilacqua about 6 years 10 months ago
Please enter configuration mode before.
Overall Rating: 5 (1 ratings)
I think I know,  it is the extention numbers and DID and username password assigned to a device.   Currently it is set to huntstop channel  and you are telling me to mak it no-huntstop channel.  The issue is that I still don;t get the syntax.
I did:  ephone-dn 14 and I get the reponce  "bad IP or hostname"
For those of you who stuumble across this thred with very little Cisco experence wondering why call waiting does not work.   well one possibility is when you activate a shared line in CCA it turns the call waiting off!
Step 1
open a command prompt,  go to your start bar and in the run filed type cmd and hit enter.  It is also located under start>all programs>accessories
step 2
type:    telnet  assuming you are connected to the UC520
if telnet does not work it may be disabled in Windows vista and Windows 7 as it was for me
go to http://www.askstudent.com/tips/howto-install-telnet-client-and-server-in-windows-vista/
step 3
login to the UC520  the default is cisco/cisco unless you changed it in CCA
step 4
type: show run
this will pull up a very long list.  Look for ephone-dn entrys.  These are the telephone number routing/peramters for your phones.   Look for the ephone number  example 10,11,14  ect   that is assigned to the phones call waiting is not working on.   You can identify by username and password or MAC address  write down the ephone numbers you need.
get back the UC520# symbol by pressing more all the way through the show run command you did.
step 5
type: config t
step 6
type: ephone-dn 14
assuming 14 is the affected phone, or else enter your ephone number you wrote down.
step 7
type: no huntstop channel
step 8
type: exit
step 9
type: exit
step 10:
type exit
step 11:
close the comand prompt
step 12:
pay it forward and answer one thred on this forum with an easy step-by-step direction for other "non-CCIE's" to be able to help them with some other issue.
