mpls xconnect will not pass data after upgrade to ES+20s
Answered Question
Dec 15th, 2009
on our MPLS network, we are in the process up upgrading to ES+20 cards.  After putting the last batch in, we're finding that syntax has changed.
I have moved the config from the unsupported sub-ints to service instances, but it's still not passing traffic.
A mpls pseudo-wire ping works fine from both directions, but data won't transfer.
If I move the termination point back to an OSM or sip600+10x1ge card it also works fine.
basic design is
end station -> switch (vlan 104) -> trunk-> PE (7600) -> GSR -> PE(7600) -> trunk -> switch -> end station
new service config is:
interface GigabitEthernet1/2
no ip address
service instance 104 ethernet
  encapsulation dot1q 104
  xconnect 10.166.8.30 104 encapsulation mpls
end
far side is:
interface GigabitEthernet4/1.104
encapsulation dot1Q 104
xconnect 10.166.8.29 104 encapsulation mpls
end
I don't completely get the rewrite config option, is that what I'm missing here?  (both 7600s are on 12.2.33 SRD3 and the ps-wire ping works perfect)
Anyone have any thoughts?
-frank
Correct Answer by Laurent Aubert about 7 years 1 month ago
Hi Frank,
As you felt it, ES-20 LC have a different implementation and so different behavior than the classical LC. Actually they are ethernet services oriented
Focussing on L2PVN, the classical LC will always pop up the outer tag (and PW will add another one with vc-type 4) but the EFP interface will do nothing by default. It means in your case you need to add the following command on the ES-20 LC interface:
rewrite ingress tag pop 1 sym
You may also find the following discussion interesting: https://supportforums.cisco.com/message/973210#973210
Laurent.
Overall Rating: 5 (1 ratings)
Correct Answer
Laurent Aubert Fri, 12/18/2009 - 07:12
Hi Frank,
Laurent.
fwalters Fri, 12/18/2009 - 07:47
Laurent,
This makes total sense and works perfectly in the lab.  It's confounded our SE, NSA and Tac handler, your help is much appreciated!
-frank
Related Content
