Internal (Default) WebAuth Message Length
Answered Question
Dec 15th, 2009
I ran into a bit of a brick wall with my WebAuth deployment and was hoping I could get a fairly quick answer.
I'm running version 4.2.207.0 on my WiSM blade.
The problem is that the text on the 'Message' field doesn't wrap. That is: if it reaches a certain length it just keeps going so that the webauth page scrolls to the right, on a single line. My security guy wants to put a wireless usage disclaimer here but it's looking like this won't be possible due to the fact his small paragraph won't wrap.
Is there any way to get around this issue? Perhaps a CLI command that I'm missing?
Correct Answer by stsargen about 7 years 2 months ago
You should be able to force the carraige return by using the html
tag.  This is a known issue in 4.2.205.0 and 4.2.207.0
Overall Rating: 5 (1 ratings)
Correct Answer
stsargen Fri, 12/18/2009 - 13:22
jpeterson6 Wed, 01/06/2010 - 13:30
That did the trick, thank you.
I was also able to add bold tags into the text to Bold the disclaimer, just as a point of interest.
