Verifying Syslog automated actions
Answered Question
Dec 15th, 2009
Dear friends,
I have some sylog messages on which i am defining an automated action. I just want to make sure that they are right.
The syslog messages that i want to try are:
1. %BGP-5-ADJCHANGE
2. %BGP-3-NOTIFICATION
Can you tell me if my settings under RME-->Tools-->Syslog-->Automated action is right?
Facility: BGP
Sub-facility: *
Seveirity : *
Mnemonic: ADJCHANGE ,NOTIFICATION
Thanks a lot
Gautam
Correct Answer by luijimen about 7 years 4 months ago
Hi Gautam,
You almost nailed it. Try the following settings instead:
Facility: BGP
Subfacility: *
Severity: 5
Mnemonic: ADJCHANG
Description:*
Facility: BGP
Subfacility: *
Severity: 3
Mnemonic: NOTIFICATION
Description:*
You will need to create 2 separate lines, one for each syslog message type. The above should match the same messages you mentioned.
Luis.
Overall Rating: 5 (1 ratings)
Correct Answer
luijimen Tue, 12/15/2009 - 14:52
  • Cisco Employee,
Hi Gautam,
Facility: BGP
Subfacility: *
Severity: 5
Mnemonic: ADJCHANG
Description:*
Facility: BGP
Subfacility: *
Severity: 3
Description:*
Luis.
gautamzone Tue, 12/15/2009 - 22:04
Thanks a lot Luis for your wonderful support.
Thanks and Regards
Gautam
