How to locate and retrieve a saved Unity v/m message
Answered Question
Dec 15th, 2009
We are using Unity 4.x with a separate server running Exchange 2000. Can someone help me in identifying the location where the "Saved" messages are saved? Thanks!
Correct Answer by Bradford Magnani about 7 years 7 months ago
Norman,
You can use Outlook Web Access (OWA) to gain access to the mailbox and delete messages that way by going to something similar to http:///exchange/ and logging in.  You should see the messages right there in the inbox.
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
Correct Answer
Bradford Magnani Tue, 12/15/2009 - 14:24
  • Cisco Employee,
Norman,
Hope that helps,
Brad
Related Content
