ISC v4.2 Restore Issue
Dec 15th, 2009
I am using ISC v4.2 and trying to do a full recovery from media failure option. Everything run smooth as expected to be until it comes to the end where it complained about a repository.before.restore.log is older than the current restore repository database, and at the end it said the restore was unsuccessful. The restore process carried on with the SLA db but the same thing happened where it complained about sla.before.restore.log, and the result was also unsuccessful. Apart from that disturbing error, everything seems to work fine.
My question is what is this *.before.restore.log at the repository directory? Are they suppose to be there for reasons or should I just delete them out before the restore process starts?
I am backing up to and restore from a remote machine map drive via nfs. It seems that the restore process take a lot and lot more time than the backup process. Let say's the backup takes about 1 hours, the restore takes more than 3 hours?! It this normal?
regards
nazmi
Related Content
