Cisco 5502 Configuration Example
Dec 15th, 2009
I'm currently running a Cisco 5508 WLC.   I currenlty want to use two Gigabit ports for Wireless traffic and I will only have 25 1142 Attached to this WLC.   Reading the Cisco Wireless LAN Controller Configuration Guide, Release 6.0 it says :
5500 Series Controller Example
For a 5500 series controller, Cisco recommends having eight dynamic AP-manager interfaces and associating them to the controller's eight Gigabit ports. If you are using the management interface, which acts like an AP-manager interface by default, you need to create only 7 more dynamic AP-manager interfaces and associate them to the remaining seven Gigabit ports.
I was hoping to use LAG for these two ports and create a Port Channel on the switch for these ports.   From Cisco's recommendation it sounds like I have to turn off LAG and create a dynamic interface for the second port and put that Port in a different VLAN.  Can anyone please shed some light on this. Everything is working at the moment but I'm just curious why this recomendation.   Any help would be greatly appreciated.
Stephen Rodriguez Tue, 12/22/2009 - 11:39
  • Purple, 4500 points or more
Lag works just fine.  can you send me the link to the document you are looking at?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
