WCS 4.1 - change default backup directory
Answered Question
Dec 16th, 2009
Does anyone know how to change the directory that WCS uses for the scheduled backup. By default it uses the ftp location specified during install, but I need to change it to another disk partition and can't see how you change it. I can do so for manual backups using dbadmin, but need to change the location used by scheduled backup permananently
Using WCS 4.1 for windows
Correct Answer by Nael Mohammad about 7 years 7 months ago
Follow the steps below:
1. To begin, stop WCS.
2. To change the FTP server root directory, navigate to   x:\Program Files\WCS4.1.xx.0\webnms\ftp-server\conf and edit the first line of the ftpd.conf file to point to the desired location.
3. To change the TFTP server root directory, navigate to   x:\Program Files\WCS4.1.xx.0\webnms\classes\com\cisco\packaging and edit the line that starts "TftpRoot=" in the file PackagingResources.properties to point to the desired location.
4. After saving the changes to these two files, restart WCS
-nael
Overall Rating: 5 (2 ratings)
Correct Answer
Nael Mohammad Wed, 12/16/2009 - 14:34
  • Silver, 250 points or more
-nael
djhurley Mon, 01/04/2010 - 03:02
Hi Nael
Thanks for the info, that has resolved the issue perfectly.
Dave
Related Content
Trending Topics - Security & Network
