ACE Load Balancing Problem
Dec 16th, 2009
I have ACE 4701 with c4710ace-mz.A3_2_2.bin image. In the current setup ACE is located in the center of network where all the WAN, Intenret and LAN is connected and ACE has default towards Internet and All other segment has default route towards ACE appliance. ACe is only redirecting the port 80 traffic to my Proxy server and bypass my lan subnet on port 80.
Internet
i
i
i
i
i
ACE--------------------------------WAN
i
i
i
i
LAN
I want to use ACE for the load balancing of two servers. Today I did the load balancing configuration but as soon as I applied the policy map on the interface vlan 200 and 300, my complete network reachability went down. When I remove the policy my network came back to normal.
192.168.200.66  FAX Server-1
192.1168.200.67 FAX Server-2
192.168.200.65   Virtual IP address
Attached is the configuration that I did on ACE for the load balancing and below is the current configuration of the ACE appliance.
access-list acl-in remark ACCESS LIST FOR ACE-INSIDE
access-list acl-in line 1 extended permit ip any any
access-list acl-out remark ACCESS LIST FOR ACE-OUTSIDE
access-list acl-out line 1 extended permit ip any any
access-list acl-proxy remark ACCESS LIST FOR PROXY SEGMENT
access-list acl-proxy line 1 extended permit ip any any
access-list acl-wan remark ACCESS LIST FOR WAN SEGMENT
access-list acl-wan line 1 extended permit ip any any
probe tcp PROBE_5050
port 5050
interval 15
passdetect interval 60
open 1
probe tcp PROBE_5101
port 5101
interval 15
open 1
probe tcp PROBE_TCP
port 80
interval 15
open 1
parameter-map type http PARAMAP_CASE
case-insensitive
no persistence-rebalance
rserver host RS_BCPR01
ip address 192.168.0.103
inservice
rserver host RS_BCPR02
ip address 192.168.0.104
inservice
rserver host RT_fax1
description Right Fax Server-1
ip address 192.168.200.66
rserver host RT_fax2
description Right Fax Server-2
ip address 192.168.200.67
serverfarm host SF_BCPR
transparent
probe PROBE_5050
probe PROBE_5101
probe PROBE_TCP
rserver RS_BCPR01
inservice
rserver RS_BCPR02
inservice
serverfarm host SF_RT_fax
rserver RT_fax1
rserver RT_fax2
sticky ip-netmask 255.255.255.255 address source STICKY-SOURCE
replicate sticky
serverfarm SF_BCPR
sticky ip-netmask 255.255.255.255 address source FAX-STICKY
replicate sticky
serverfarm SF_RT_fax
class-map type management match-any CM_ALL
2 match protocol snmp any
3 match protocol http any
4 match protocol https any
5 match protocol icmp any
6 match protocol telnet any
class-map match-any CM_BYPASS_FOR_LAN
3 match virtual-address 100.1.1.0 255.255.255.0 tcp eq www
8 match virtual-address 10.0.0.0 255.0.0.0 tcp eq www
9 match virtual-address 172.16.0.0 255.255.0.0 tcp eq www
10 match virtual-address 192.168.0.0 255.255.0.0 tcp eq www
class-map match-any CM_BYPASS_SUBNET
9 match virtual-address 100.0.0.0 255.0.0.0 tcp eq www
13 match virtual-address 10.0.0.0 255.0.0.0 tcp eq www
14 match virtual-address 172.16.0.0 255.255.0.0 tcp eq www
15 match virtual-address 192.168.0.0 255.255.0.0 tcp eq www
class-map match-any CM_IM
2 match virtual-address 0.0.0.0 0.0.0.0 tcp eq 5050
3 match virtual-address 0.0.0.0 0.0.0.0 tcp eq 1080
4 match virtual-address 0.0.0.0 0.0.0.0 tcp eq 5101
class-map match-all CM_SF_BCPR
255 match virtual-address 0.0.0.0 0.0.0.0 tcp eq www
class-map match-any RT_FAX
2 match virtual-address 192.168.200.65 0.0.0.0 any
policy-map type management first-match PM_ALL
class CM_ALL
permit
policy-map type loadbalance http first-match PM_L7_BYPASS_FOR_LAN_HTTP
class class-default
forward
policy-map type loadbalance http first-match PM_L7_BYPASS_HTTP
class class-default
forward
policy-map type loadbalance first-match PM_LB_RT_FAX
class class-default
sticky-serverfarm FAX-STICKY
policy-map type loadbalance http first-match PM_LB_SF_BCPROXY
class class-default
sticky-serverfarm STICKY-SOURCE
policy-map multi-match PM_BYPASS_FOR_LAN_HTTP
class CM_BYPASS_FOR_LAN
loadbalance vip inservice
loadbalance policy PM_L7_BYPASS_FOR_LAN_HTTP
policy-map multi-match PM_BYPASS_HTTP
class CM_BYPASS_SUBNET
loadbalance policy PM_L7_BYPASS_HTTP
policy-map multi-match PM_MAIN_BCPROXY
class CM_SF_BCPR
loadbalance policy PM_LB_SF_BCPROXY
loadbalance vip icmp-reply active
appl-parameter http advanced-options PARAMAP_CASE
class CM_IM
policy-map multi-match PM_RT_FAX
class RT_FAX
loadbalance policy PM_LB_RT_FAX
service-policy input PM_ALL
interface vlan 100
description FW-INSIDE CONTEXT RACK1
ip address 192.168.0.5 255.255.255.224
alias 192.168.0.11 255.255.255.224
peer ip address 192.168.0.6 255.255.255.224
mac-address autogenerate
no icmp-guard
access-group input acl-out
no shutdown
interface vlan 200
description WAN-VLAN CONTEXT RACK1
ip address 192.168.0.33 255.255.255.224
alias 192.168.0.43 255.255.255.224
peer ip address 192.168.0.34 255.255.255.224
access-group input acl-wan
service-policy input PM_BYPASS_HTTP
service-policy input PM_MAIN_BCPROXY
no shutdown
interface vlan 300
description ACE-INSIDE CONTEXT RACK1
ip address 192.168.0.65 255.255.255.224
alias 192.168.0.73 255.255.255.224
peer ip address 192.168.0.66 255.255.255.224
access-group input acl-in
service-policy input PM_BYPASS_FOR_LAN_HTTP
no shutdown
interface vlan 301
description BC-VLAN CONTEXT RACK1
ip address 192.168.0.97 255.255.255.224
alias 192.168.0.107 255.255.255.224
peer ip address 192.168.0.98 255.255.255.224
access-group input acl-proxy
no shutdown
ft track interface TRACKING_FOR_FT_VLAN
track-interface vlan 300
peer track-interface vlan 300
priority 255
peer priority 255
ip route 0.0.0.0 0.0.0.0 192.168.0.1
Please help me out what i am missing. Is there any limitation on policy map or my bypass subnet list is creating problem.
Gilles Dufour Thu, 12/17/2009 - 02:21
You should configure everything you did, without adding the service-policy to the interface.
Then add one policy at a time to one interface only.
See if it breaks anything.
See if it works.
Then proceed like this until you see which step create a problem.
We can then investigate further.
G
wasiimcisco Fri, 12/18/2009 - 04:15
I did these changes this time nothing disconnected but I am not able to do the Remote desktop on the virtual IP address. Real IP has Remote desktop enabled even VIP is not ping able for me.
  inservice
  inservice
  rserver RT_fax1
    inservice
  rserver RT_fax2
    inservice
policy-map type loadbalance rdp first-match PM_LB_RT_FAX
  class class-default
  class RT_FAX
interface vlan 200
  service-policy input PM_RT_FAX
  no shutdown
interface vlan 300
  no shutdown
But nothing is working for me. Please help me out. This time i didnt configure the sticky. But in real I will go with sticky and complete IP protocol will be use a VIP. Please help me out.
wasiimcisco Fri, 12/18/2009 - 04:24
show stats loadbalance rdp
+------------- Rdp Loadbalance statistics -------------+
Total parse results received                  : 0
Total packets load balanced                   : 0
Total packets with routing token              : 0
Total packets with token matching no rserver  : 0
how service-policy  PM_RT_FAX
Status     : ACTIVE
Interface: vlan 1 200 300
  service-policy: PM_RT_FAX
    class: RT_FAX
      loadbalance:
        L7 loadbalance policy: PM_LB_RT_FAX
        VIP ICMP Reply       : ENABLED-WHEN-ACTIVE
        VIP State: INSERVICE
        curr conns       : 0         , hit count        : 0
        dropped conns    : 0
        client pkt count : 0         , client byte count: 0
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
      compression:
        bytes_in  : 0
        bytes_out : 0
        Compression ratio : 0.00%
Gilles Dufour Mon, 12/21/2009 - 11:37
if this is your class map, it does not look right.
Remove the 0.0.0.0
Gilles.
wasiimcisco Mon, 12/21/2009 - 21:05
Thanks for the reply,i already tried last week and it is working fine for me.
