Redistributing OSPF into BGP using route-map
Answered Question
Dec 16th, 2009
I am trying to redistribute a single IP from OSPF into BGP...
You can see the ACL where I want to redistribute the single IP and not the entire subnet...but I don't see it in the BGP routing table...
Any ideas?
router ospf 100
log-adjacency-changes
area 0 authentication message-digest
redistribute bgp 65001 subnets
network 10.10.10.0 0.0.0.255 area 0
default-information originate metric 100
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
redistribute ospf 100 match internal external 1 external 2 route-map redistributeospf
neighbor 12.92.177.113 remote-as 7018
no auto-summary
ip access-list standard redistributeospf
deny   10.10.11.254
permit 10.10.11.0 0.0.0.255
route-map redistributeospf deny 10
match ip address redistributeospf
route-map redistributeospf permit 20
Correct Answer by marikakis about 7 years 2 months ago
I am still trying to understand what you are trying to do. Can you explain why the first clause of the route-map is a 'deny' clause?
Overall Rating: 5 (2 ratings)
trippi Wed, 12/16/2009 - 07:22
When I do a 'sh ip bgp' all my ospf routes are being redistributed except the subnet 10.10.11.0/24.  (Which is what I want minus the single IP)
Jerry Ye Wed, 12/16/2009 - 08:19
Then your redistribution should work since the OSPF routes make it into the BGP table. Can you have someone verify the remote side?
jerry
Correct Answer
marikakis Wed, 12/16/2009 - 08:58
Jerry Ye Wed, 12/16/2009 - 09:35
Hi Maria,
You are right on spot. I've missed that totally (read it too fast).
If 10.10.11.254 is the only IP address that should not be redistributed into BGP the route map should look like this
route-map redistributeospf permit 10
+5 for you Maria.
jerry
