Removing DID digits in SRST Mode
Dec 16th, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I'm getting 8 digits from the Telco and we use 7, I'm having a hard time finding out how to remove the first digit.
Example - incoming DID number 47111309 extension number 7111309
Thanks for the help
Overall Rating: 5 (1 ratings)
asandborgh Wed, 12/16/2009 - 07:47
  • Silver, 250 points or more
Use a voice translation-rule/profile and applyy it to an inbound dial-peer that is catching the DID or directly to the port (although this will trim it to 7 digits even when you are not in SRST).
Something like this:
voice translation-rule 1
rule 1 /4711..../ /711..../
voice translation-profile indid
translate called 1
dial-peer voice 1000 pots
incoming called .
direct-inward-dialing
translation-profile in indid
Art
spatrick73 Wed, 12/16/2009 - 07:52
I have tried that but I'm getting an error
(cfg-translation-rule)#rule 1 /4711..../ /711..../
% Invalid input detected at '^' marker.
asandborgh Wed, 12/16/2009 - 07:56
Duh!
Sorry I'm rusty..
Try
rule 1 /4711\(....\)/  /711\1/
Art
asandborgh Wed, 12/16/2009 - 08:25
np - glad to hear it helped
Cheers!
Art
Related Content
