Tacacs authorization for Nexus5000 on ACS
Dec 16th, 2009
I'm trying to configure authorization for a Nexus5020 and I cant find what I'm supposed to configure in ACS...
If I wanted to do Radius, it would be easy, simply provide as a Cisco-av pair " shell:roles=roleA ". The documentation does not say anything about configuring attribute for tacacs.
Alex Pfeil Mon, 12/21/2009 - 04:40
Here is a link for the config on the Nexus:
If  this is what you are working with and you are using the GUI on the ACS, all you need to configure is:
allow the ip address of the Nexus to talk to the ACS
configure a pre-shared key on the ACS under TACACs
It is very similar to setting up radius.
Hope this is what your looking for.
jcerero77 Thu, 03/11/2010 - 14:36
Hello Dominic,
I am trying to set up my cisco switches to use Radius using my  ACS, however I am not finding any documentation do you still have the documentation for how to set up radius on ACS. If you have examples that would be helpful too, thanks!
