Ciscoworks LMS RME / ASA Firewall configuration pre-shared key savings
Dec 16th, 2009
Does anybody know the concept about saving pre-shared by Ciscoworks LMS /RME ?
Is there a way to get the unencrypted values from Ciscoworks LMS /RME for an ASA Firewall ?
ASA config. saved with RME
pre-shared-key *
ASA config. saved to TFTP from ASA
pre-shared-key 1ZdmaKVwEkQ66nD37d9kA9fj9z75
yjdabear Wed, 12/16/2009 - 08:35
  • Gold, 750 points or more
If you enable "shadow directory" (RME - Admin - Config Mgmt - Archive Mgmt - Archive Settings), you can find the raw configs in locations such as /var/adm/CSCOpx/files/rme/dcma/shadow/Security_and_VPN/PRIMARY on Solaris, or its Windows equivalent, after one requisite cycle of Periodic Polling and/or Periodic Collection. That's the same config one'd get saving to TFTP manually.
However, I don't recall how to unscramble the "asterisks" in the RME GUI, if at all possible.
Related Content
