is SCOM compatible with CUCM 4.X MCS-7800 server?
Answered Question
Hi All,
I am asked if we can install the SCOM client on the MCS Server where we have the Cisco Callmanager Cluster and Unity, anyone know if SCOM is compatible with the MCS servers? any impact?
Andres Cerda
Correct Answer by Jaime Valencia about 7 years 3 months ago
It's not supported
Third-Party Platform Agents Running with Cisco CallManager
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_bulletin0900aecd800f8572.html
For Unity open the correct doc depending on version:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
Supported Hardware and Software, and Support Policies for Cisco Unity Release X.X
I believe it's also not supported on Unity.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 12/16/2009 - 11:22
  • Cisco Employee,
  • Hall of Fame,
    2011
It's not supported
java
