IP SLA for dual Internet links
Dec 16th, 2009
Dear friends,
I have configure ip sla monitor for redundant ISP links on the ASA. The ASA version is 8.2(1).
I configured as per the link
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
I tested failover and the routing table is properly updated to point to the proper next hop.
However, i am having issues with xlate.
The old xlate entry never times out. Everything seems to work only after i say clear xlate.
I dont know why new xlate is not getting created. So, now failover is working fine only i after i manually issue the command clear xlate.
Is there a way to clear the old translation entries automatically without having to manually clearing them
A snippet of my config is as follows:
nat (inside) 1 0 0
global (outside) 1 interface
global (outside2) 1 interface
sla monitor 1
type echo protocol ipIcmpEcho 212.77.192.59 interface outside
num-packets 3
frequency 10
route outside2 0.0.0.0 0.0.0.0 78.100.48.18 200
sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
route outside 0.0.0.0 0.0.0.0 10.101.2.254 1 track 1
I am using ASA 5510 with 8.2(1) code.
Thanks a lot
Gautam
gautamzone Thu, 12/17/2009 - 06:19
Dear Andrew,
Everything seemed to work fine when i went physically to the site.
I did not have to change the xlate timeout. Probably i should have tested it physically first.
Thanks a lot for the help
Thanks a lot
Gautam
