External busy trigger to reroute to another call?
Dec 16th, 2009
  • Green, 3000 points or more
Im not sure if this is possible.
Customer wants to dial a 4 digit number, which then translates to 915551212.   Apparently this 915551212 number can get go to a busy no answer tone from time to time.  They want it to then roll to another number say 94085551212.
I tired to use a CTI fill in the destinations, it will not work. (not really whats its for anyways)
I dont think a fake phone will work either because the only way a busy trigger can happen is if the phone is actually set to 1 call, and is used, then goes to the next rule in the destination list.
Route Pattern, to Route List, Route Group is really only for if a gatway fails to go to the next list.
Any other alternatives to configure this?  Im out of possibilities other than maybe something with Unity like a supervised call, but not sure that will even work.
Cheers
asandborgh Thu, 12/17/2009 - 06:57
  • Silver, 250 points or more
Hi there,
If it is a PRI you might be able to do something like this:
go to service parameters and set both "stop routing on unallocated" and "'stop routing on busy" to false
Do a normal translation on the 4 digit to 915551212
build a second RG in you RL, include the same gateway and mask the called number on that RG with the second number (94085551212)
I can't guarantee anything but I don't see why it wouldn't work - on a PRI.  If it is an FXO the CCM has no way of knowing it is receiving busy.
HTH,
Art
