12-16-2009 02:06 PM - edited 03-06-2019 08:59 AM
Hello all,
I already know that for 6509 we have the WS-C6K-9SLOT-FAN, and for high speed, the WS-C6K-9SLOT-FAN2.
For 6509-E we have the WS-C6509-E-FAN.
The question is...
Can i use the WS-C6509-E-FAN, in one WS-C6509 ? Will it fit in the chassi, and will it work ?
Best Regards,
Bruno Petrónio
Solved! Go to Solution.
12-16-2009 07:11 PM
The E fan tray doesn't fit the none-E chassis. Same thing apply to the none-E fan tray and E chassis.
jerry
12-16-2009 07:11 PM
jerry
12-16-2009 07:20 PM
Hi Bruno,
As Jerry noted the E fan try does not work with none E series.
To upgrade your regular 6509 to use sup720 you have to use this part
number for fan try
WS-C6K-3SLOT-FAN2
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_qas09186a0080159963.html
Reza
12-16-2009 08:23 PM
E chassis fan tray wont work ina normal chassis :-
Hope that helps.
Varun
