one way audio vg224
Dec 16th, 2009
Anyone remember what the command is that fixes one way audio on vg224?   I already have no ip routing turned on and I still get one way audio between VG224 port and IP phone on the same switch, etc.  I know its not network related and I had this problem before somewhere.  Just cant recall what command goes in the vg224 to fix this.
Tommer Catlin Wed, 12/16/2009 - 14:41
actually I had to remove no ip routing
so turned ip routing on I guess and it worked fine.
Kevin Monteiro Tue, 02/11/2014 - 18:10
Hi Tommer,
Have you tried checking the cabling, i mean the patch panel?
Kindly rate the post accordingly.
Kevin
