ACS console password recovery
Dec 16th, 2009
can someone help me to double check this:
If use this procedure: http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/install/admap.htm#1038722 to reset the console password of my ACS appliance will I lose any configurations?
I only reset the admin credentials right?
Thank you.
Best regards,
sapatel Wed, 12/16/2009 - 16:12
No, you will not lose your configuration, but I would suggest taking a back up of your configuration anyway.
