antenna pole/rod suggestions
Dec 16th, 2009
I am just looking to pick the minds of technicians that have dealt with outdoor deployments. What solution did you result to for your out door access points? I am working on a solution but some pointers here in there about which vendors to use for pole/rod equipment and other nuances would be hepful. thank you.
Overall Rating: 4.5 (2 ratings)
jeff.kish Tue, 12/22/2009 - 14:25
  • Silver, 250 points or more
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b.html
Check out this document.  I've personally used the AIR-ANT2460P-R and AIR-ANT2506 for client access.  All other antennas listed as outdoor antennas can be used as well, you just need to find what your environment requires.  Use this is conjuction with the doc lavramov provided (+5 to him for the link).
Jeff
