Best method to rotate syslog_info on LMS 3.2
Dec 16th, 2009
What is the best method to rotate the syslog_info file on Solaris?
Currently I have been using logadm which I think is causing issues.
Cheers,
Sigfrid
Joe Clarke Wed, 12/16/2009 - 20:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should use the included /opt/CSCOpx/bin/logrot.pl script.  You can configure log file rotation under Common Services > Server > Admin > Log Rotation.
If you must use logadm, use the -c option to make sure the inode number doesn't change when rotating syslog_info.
Related Content
