Help configuring Frame-relay
Answered Question
Dec 16th, 2009
I have 3 2600 series routers and I have configured R1 as FR switch and have configured for static mapping for the remaining two routers. Listed below is the configuration file of all the routers, and I have run all frame-relay specific commands and everything indicates that it is working but I cannot ping R2 from R3 and vice versa.
R1 configuration
Current configuration : 1170 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname R1
enable password xxxxx
ip subnet-zero
ip ftp username cisco
ip ftp password cisco
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
frame-relay switching
interface Ethernet0/0
ip address 192.168.1.40 255.255.255.0
half-duplex
interface Ethernet0/0.1
interface TokenRing0/0
no ip address
shutdown
ring-speed 16
interface Serial1/0
no ip address
shutdown
no fair-queue
interface Serial1/1
no ip address
encapsulation frame-relay
clockrate 64000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 200 interface Serial1/2 100
interface Serial1/2
no ip address
clockrate 64000
frame-relay route 100 interface Serial1/1 200
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 192.168.1.0
network 192.168.10.0
no auto-summary
eigrp log-neighbor-changes
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password cisco
login
R2 configuration
version 12.2
hostname R2
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip address 192.168.10.1 255.255.255.224
half-duplex
interface Serial0/0
ip address 192.168.10.66 255.255.255.252
frame-relay map ip 192.168.10.70 100 broadcast
no ip address
shutdown
ring-speed 16
router eigrp 1
no auto-summary
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password cisco
login
end
R3 configuration
version 12.2
hostname R3
ip subnet-zero
ip ftp username xxxx
ip ftp password xxxx
no ip domain-lookup
ip audit notify log
ip address 192.168.10.33 255.255.255.224
half-duplex
interface Serial0/0
ip address 192.168.10.70 255.255.255.252
frame-relay map ip 192.168.10.66 200 broadcast
no ip address
shutdown
ring-speed 16
router eigrp 1
no auto-summary
ip classless
ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password cisco
login
end
Here's some of the output of the commands that I run to troubleshoot it.
R1 #sho frame-relay route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
Serial1/1       200             Serial1/2       100             active
Serial1/2       100             Serial1/1       200             active
R2 #show frame-relay map
Serial0/0 (up): ip 192.168.10.70 dlci 100(0x64,0x1840), static,
              broadcast,
              CISCO, status defined, active
R3 #sh frame-relay map
Serial0/0 (up): ip 192.168.10.66 dlci 200(0xC8,0x3080), static,
              broadcast,
R1 #sh frame-relay pvc
PVC Statistics for interface Serial1/1 (Frame Relay DCE)
              Active     Inactive      Deleted       Static
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         0            0            0            0
DLCI = 200, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial1/1
  input pkts 1177          output pkts 1185         in bytes 75328
  out bytes 75840          dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
switched pkts 1176
  Detailed packet drop counters:
  no out intf 0            out intf down 0          no out PVC 0
  in PVC down 0            out PVC down 0           pkt too big 0
  shaping Q full 0         pkt above DE 0           policing drop 0
  pvc create time 20:46:09, last time pvc status changed 20:45:52
PVC Statistics for interface Serial1/2 (Frame Relay DCE)
  Local          0            0            0            0
  Switched       1            0            0            0
  Unused         0            0            0            0
DLCI = 100, DLCI USAGE = SWITCHED, PVC STATUS = ACTIVE, INTERFACE = Serial1/2
  input pkts 1186          output pkts 1176         in bytes 75904
  out bytes 75264          dropped pkts 0           in pkts dropped 0
  switched pkts 1185
  pvc create time 20:46:10, last time pvc status changed 20:45:50
From above everything should work but I cannot ping any host nor does show ip route shows any adjacent routers. Any help is greatly appreciated.
Correct Answer by jgagznos about 7 years 3 months ago
Check your IP addressing.  R2 and R3 serial interfaces are on different subnets.  Fix that and see if you can get it to work!
Overall Rating: 5 (1 ratings)
Correct Answer
jgagznos Wed, 12/16/2009 - 16:54
osman97229 Wed, 12/16/2009 - 19:19
That fixed the problem. Thank you for the quick reply. I have been struggling this for awhile.
