Problems with patching: ACS 5.0 to 5.1 upgrade
pkemp
I'm following the instructions to upgrade from ACS 5.0 to 5.1
But I can't get past the first step:
Step 1 Install the ACS 5.0 patch:
Issue the following acs patch command in the EXEC mode to install the ACS patch:
acs patch install patch-name.tar.gpg repository repository-name
Here is my output:
***/admin# acs patch install 5-0-0-21-9.tar.gpg repository mytftp
chmod: cannot access `*.sh': No such file or directory
Error: Failed to open patch 5-0-0-21-9.tar.gpg
It downloads the patch ok via TFTP, but can't install it.
Can anyone help?
Peter
2 Accepted Solutions
jrabinow
Level 7
Level 7
There are problems in 5.0 with using tftp for file transfers that exceed 32Mb. There can also be some issues with ftp servers that exceed this limit.
I recommend to retry using alternative repository type. For example ftp or a repository local on the server.
Erick Delgado
You need to use and FTP server as repository I suggest using filezilla server is free and usefull.
Please see attach document that will explain you how to upgrade your ACS.
Hope this help!
Have a great weekend!
jrabinow
Level 7
Level 7
Erick Delgado
Hope this help!
Peter Koltl
Level 7
Level 7
ACS 5.1's TFTP seems to be broken, even under 32 MB:
csacs/admin# copy tftp://192.168.159.1/5-1-0-44-1.tar.gpg disk:
csacs/admin# dir
Directory of disk:/
   10660640 Apr 29 2010 08:56:05  5-1-0-44-1.tar.gpg
      16384 Apr 29 2010 07:34:04  lost+found/
           Usage for disk: filesystem
                   54554624 bytes total used
                 4867284992 bytes free
                 5185241088 bytes available
csacs/admin# copy
Username: ftp
Password:
csacs/admin# dir
Directory of disk:/
   10660971 Apr 29 2010 08:57:57  5-1-0-44-1.tar.gpg
I couldn't install the patch with tftp (not surprisingly).
