PIX 515 7.2(1) always reload
Answered Question
Dec 16th, 2009
Hi All,
   I have a big problem, I hope you can help me here. Since yesterday, I found out that my Pix Firewall keeps reloading until now. Is there someone out there experience this thing? Please help!!
many thanks,
reymon
Correct Answer by yamramos.tueme about 7 years 4 months ago
Hi Reymon!
Have you checked if the ASA is crashing?  You can check by using the "show crash" command and if it is it will give you a big output.  You can also try setting a syslog; perhaps this can help you to get more information on what is going on.
Cheers!
- Yamil
Overall Rating: 5 (1 ratings)
Correct Answer
yamramos.tueme Thu, 12/17/2009 - 11:03
Hi Reymon!
Cheers!
- Yamil
Mhon Baul Wed, 12/23/2009 - 21:49
Hi Yamil,
  Thanks for your reply. I check the crash file and  send to a cisco partner and they told me that the IOS is hit by a bug. I upgrade the IOS to 7.2(3) and so far  its not reloading anymore.
reymon
vilaxmi Fri, 12/25/2009 - 23:24
  • Cisco Employee,
Yes, they are right. Your OS on the firewall was definitely hit by a bug. I have seen such issues on a failover pair running 7.2.. version where active gets stuck in a reload cycle. I don't remember the exact bug ID on top of my mind, though I guess its a public bug which you can pretty much dig.:).
Cheers.
Vijaya
PAUL GILBERT ARIAS Thu, 12/17/2009 - 14:42
  • Silver, 250 points or more
Is this a failover unit? How often it reloads? Do you have a crash file or logs?
