Partitions in Unity Connection
Dec 16th, 2009
Does anyone know what the "/spare" partition is used for in Unity Connection?
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda1             17046052   5800212  11072660  35% /
/dev/sdb1             70444596  47572404  19293716  72% /common
/dev/sda3               256665      8413    234999   4% /grub
/dev/sda2             17046084     32828  16147356   1% /partB
none                   2043840     22292   2021548   2% /dev/shm
/dev/sda6             34076068     32828  32312240   1% /spare
Overall Rating: 5 (1 ratings)
WSonnylal Thu, 12/17/2009 - 09:06
Thanks for the reply.  It's a lot of space for spare logs.  Is it possible to reclaim some of that space and use it in the common partition?
