12-16-2009 11:39 PM - edited 03-11-2019 09:49 AM
I went to a customer has ASA 5510 Version 8.0(4) but i couldn't access ASDM.
here is the configuration
any one can help
thank you
12-16-2009 11:48 PM
First check the flash if you have image of asdm:
show flash:
asdm-615.bin would be the image name may be 611 also depends.
as per the image in flash config boot (its not in your configs)
asdm image disk0:/asdm-XXX.bin
Update you java on machine which you would be accessing the ASDM just in case.
Neuromancer....
12-16-2009 11:55 PM
1. the asdm image exist in the flash and \
2. I write this command into his asa
asdm image disk0:/asdm-615.bin
3. in the same day I went to another customer I could access asa throught asdm
so it is not java problem
12-17-2009 10:58 AM
What interface are your trying to hit? From what IP address?? It could be that you are missing the
http
Cheers!
- Yamil
12-17-2009 02:49 PM
Can you please provide the following:
sh flash
sh run asdm
Just to make sure things are fine.
Have you tested from a different host to access the ASDM or using the ASDM launcher?
12-17-2009 02:50 PM
sh flash
sh run asdm
12-17-2009 02:53 PM
sh flash
sh run asdm
12-17-2009 02:55 PM
Sorry, the message was sent several times by mistake.
