MS-NAP
Answered Question
Dec 17th, 2009
First, I'm not Bilingual so excuse my English.
Dear Sirs,
Does Catalyst2960G have the function of "EAPoL Forwarding"?
I want to use it in the "MS NAP" environment.
Best regards,
Correct Answer by Jatin Katyal about 7 years 1 month ago
Further to my last post, forwarding you simple configuration example of 802.1x with NPS
Simple Configuration of Microsoft NPS as Radius for 802.1X - Part 1
http://communities.intel.com/docs/DOC-4321;jsessionid=6F81E543145EF7569F1EF66EC0AE6CD0.node5COMS
Simple Configuration of Microsoft NPS as Radius for 802.1X - Part 2
http://communities.intel.com/docs/DOC-4322;jsessionid=5A8B2CE3BB81643BEA3B0A02E83AC09F.node5COMS
JK
Plz rate helpul posts-
Greetings:
Yes, 2960G does supports 802.1x authentication (EAPOL forwarding).
For you reference:
Configuring IEEE 802.1x Port-Based Authentication
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/sw8021x.html
Please let me kknow if you have any further queries.
JK
Plz rate helpful posts-
Overall Rating: 5 (2 ratings)
Correct Answer
Jatin Katyal Sun, 01/10/2010 - 02:04
JK
Related Content
