WRVS4400N-EU router and VPN connection from x64 system
Dec 17th, 2009
I would like to buy a WRVS4400N-EU router for my small business, all PC's and laptop's i my company have Windows 7 x64, my question is:
1. Does QuickVPN works on Windows 7 x64 ?
2. Does WRVS4400N-EU router support Cisco Anyconnect VPN Client ?
3. Is there any other application with support connect to this router from x64 systems ?
4. Does VPN connection between this router and client PC requires a dedicated VPN Client Application to connect or mayby just standard windows wizzard.
twistedpixel Thu, 12/17/2009 - 18:10
As for your first question, I am currently testing QuickVPN on Win7 x64 and it does not appear to work.  Error says,"QuickVPN client requires Windows 2000 or XP".  Would love to know if anyone knows of a way to make this work.  I haven't gotten as far as shimming yet.. .maybe this is just an OS version check error and can be side-stepped?
oracertified2000 Thu, 01/07/2010 - 04:55
Bad news. I just bought this router (4400N) at a retail store for $239.00 with a ship date of 12/2009
and the QuickVpn client will NOT work with Windows 7. Furthermore, I do not see any
signs of Cisco fixing this.
Cisco has spent more time enabling a social networking community than to make this product work or any kind of work around.
I would be happy if I could use the pptp and the MS Clients. There is no pptp option in the 4400N. All I can do is port forward to my MS server. This does work, but then I cant vpn out....
Unfortunately, I will have to return this router for a "STORE CREDIT" . This product should be removed from the shelves and recalled until the client works with Vista and Windows 7 in any way or fashion.
Thanks Cisco.
Yes, I did install the 1.3 version and I even tried it in compatibility mode for XP.
