how to configure congurent interop session between CTMS&CUVC
Dec 17th, 2009
Is any solution guide or write-up available to enable more than one congruent interop session between CTMS & CUVC? Do we need to configure more than one SIP trunk between CUVC & CTMS.
Please suggest steps or forward write-up.
Thanks.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Fri, 12/18/2009 - 05:17
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
what did you mean exactly in more than one session !! do you mean more than one meeting at the same time ?
if this is the case then just create another meeting number in the CUVC
then in call manager creat a new route pattren witht the same numbr you created in cuvc and point to the same SIP trunk you have pointing to the CUVC
good luck
if helpful Rate
Tod Larson Sun, 12/20/2009 - 01:22
I agree with the previous post.  Simply do the same procedure to continigure interop again for a different set of phone numbers.  You can use the same SIP trunk as before.  You could also edit the previous config using wild cards if you dial plan supports it.
