Can I change the STP mode on VSS without reload?
Answered Question
Dec 17th, 2009
  • Gold, 750 points or more
Hello all,
I have two Catalyst 6506 in VSS mode with STP running PVST mode.
The question is...
When I change the STP mode on the VSS, I found the following message.
VSS(config)#spanning-tree mode mst
%Changing the STP mode will reset the standby VSS.
Do you want to proceed? ? [yes/no]:
Is this the feature of the VSS???
If so,are there any reference to it in any of the docs?
Best Regards,
Tomoyuki
Correct Answer by vvasisth about 7 years 5 months ago
this warning is valid. In some corner cases while changing STP
mode, the active STP has switched to the new mode and has started
sending HA sync messages for the new protocol. The standby is still in
the old mode (the mode change has not kicked in yet or in progress) and
the incoming HA sync messages are incompatible. The exisiting code
processes these message and caused a memory corruption leading to the
crash.
Here is the exact match for your issue :-
CSCsy93171
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello Tomoyuki,
you are right for example best practices document for VSS does not mention this and actually there is no section for STP mode change.
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
and there is no note in command reference:
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_s2.html#wp1015453
We know that from outside the VSS presents itself as a single box, I wonder if STP mode has effects on the VSL link or the reload is caused by the need to be sure that standby supervisor config is taken from the active one. Or it can be a SW defect.
What IOS version are you running in your VSS?
Hope to help
Giuseppe
Overall Rating: 5 (4 ratings)
Correct Answer
Giuseppe Larosa Thu, 12/17/2009 - 02:22
  • Hall of Fame,
    Founding Member
Hello Tomoyuki,
Hope to help
Giuseppe
Correct Answer
vvasisth Thu, 12/17/2009 - 02:23
  • Silver, 250 points or more
crash.
CSCsy93171
t-yamashita Thu, 12/17/2009 - 03:14
At first, my VSS is running 12.2(33)SXH and I found the message.
But now, I upgraded to 12.2(33)SXI and didn't appear it.
Thank you for all of your help.
Best regards,
Tomoyuki
