modem issue in 3660
Dec 17th, 2009
  Hi guys, i have an cisco3660 router with 30 port digital modem (NM-30DM=) and 1 pri line from telecom, this is used for POS devices to dial-up on it. There is an autocommand on lines to connect POS's tho the proccesing server, but now our institution has purchased new POS devices which will connect to another server. Initialy whe have divided our pri line to 2 numbers with 15 channels, but the problem is when the call is comming it is forwarded on differnent modem lines, how can i setup that if call is comming on common number 111-111 it forwards the data on the modem lines from 0-14 edhe when the call is comming on the second number 222-222 it forwards the data to modem lines from 15-29. I hope i was clear.
Thnx in advance
Overall Rating: 3 (1 ratings)
Ronit Bhattacharjee Thu, 12/17/2009 - 06:39
  • Bronze, 100 points or more
Hi Shen,
Try modem pooling
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094898.shtml
In your case the configuration should look something like this
modem-pool pool1
 pool-range 0-14
 called-number  111111 max-conn 15
modem-pool pool2
 pool-range 15-29
 called-number 222222 max-conn 15
Check your modem's data sheet to see if it does support modem pooling, but going from the minimum IOS required, the modems should work.
Hope this helps
Shen Gjeli Fri, 12/18/2009 - 00:41
Hi Ronit,
  Modem poolling feature is not applicable on cisco 3600 series routers. I have to find another solution. Thanks for your reply it was really helpfull, to find a starting point, we should upgrade our router to addopt to this solution.
