Setting up ACS 4.2 to authenticate MSFC's and ACE modules ?
Dec 17th, 2009
Has anyone seen an issue whereby you have setup custom attributes for users to be able to logon to the ACE modules and get to the Admin context and also be able to log on to MSFC's ?  At present I can only do one or the other as if I leave the custom attributes on in the Shell(Exec) section then I cant login to the MSFC's, but then when I take the custom attributes off we cant login to the ACE modules but can the MSFC's !  Is there a way round this or should the setup be different ?
Cheers
Florrieford
