ACS SSL Initiation
lars.molstad
Hi folks,
I have some trouble with a End-to-End SSL configuration on my ACE...
SSL Termination works like a dream, and with backend unencrypted traffic, everything works fine, but...
I am trying to get some elements (using match http url) from another server running https.
I can get a connection to the other server, so connectivity should be Ok.
I suspect this is due to url-rewrite on the https back-end server. (Every request is redirected to the URL of the server instead of the IP-address)
Is it possible to insert this host-header into my requests, to get this work?
Br
L@rs, CCIE 14647
lars.molstad
Hi all,
I figured out how to modify the "Host" value in the request, so now it's working like a dream.
L@rs
