Config file from 4400 controller to 5500
Dec 17th, 2009
A quick question: can I upload a config file from 4400 series controller and download it to 5500 controller? Does this work or do I have to do everything from scratch?
Software versions:
4402 controller: 4.2.207.0 (MD)
5508 controller: 6.0.188.0 (ED)
Thanks.
-Petri
Stephen Rodriguez Tue, 12/22/2009 - 06:09
  • Purple, 4500 points or more
you would probably be better served doing it from scratch.  while it could be possible to upload the config, you can't change anything in the XML config that 4.2 outputs.
