Reset Factory Default IP Phone 7912
Dec 17th, 2009
Hi Guys,
Anybody informe to me, if there are any procedure to reset factory default IP Phone 7912. I try search in the Cisco Site but didn´t found
Wilson Santana
Overall Rating: 5 (1 ratings)
wilsonsant Thu, 12/17/2009 - 06:23
Hi Asandborg,
I am sorry, I try apply this procedure, but, didn´t work.
asandborgh Thu, 12/17/2009 - 06:26
When you say "didn't work" -  please explain what didn't work.  What is the phone doing or not doing?  Did this phone ever work?  When it boots what is the behavior?
rob.huffman Thu, 12/17/2009 - 06:30
Hey Wilson,
This method was posted by Jorge from ALESTRA SA DE CV
Step 1 Press the Menu button.
Step 2 Use the Navigation button to select Settings.
Step 3 Use the Navigation button to select Network Configuration.
Step 4 Perform one of the following procedures:
Procedure A:
- Press **2. The phone displays "Do you want to reset all system settings to default
- Press the Yes softkey.
Procedure B:
- Press **#. If your phone displays "Enter Admin Password," enter your password and then
press the Enter softkey. Make sure that an unlocked padlock icon appears in the
upper-right corner of your LCD.
- Scroll to Erase Configuration.
- Press the Yes softkey and then press the Save softkey.
The phone cycles through normal startup procedures.
Maybe this will work.
