VWIC2-1MFT-T1/E1 Data Rate
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Thu, 12/17/2009 - 07:16
E1 is 2 mbps - fixed.
If you upgrade to 4 mbps using E1, the SP will provide a second circuit and you will need 2 interfaces more.
Giuseppe Larosa Thu, 12/17/2009 - 07:17
Hello Graeme,
E1 is limited to 32 timeslots 64 kbps each, it can be used unframed or framed.
There are other serial interfaces that can have an higher bit rate but not if they are based on E1 standard
you should deploy two E1 links with multilink PPP for example if this is your hardware.
Hope to help
