vg 224 not getting registered in call manager 6.1(3)
Dec 17th, 2009
hi
we are having call manager 6.1(3) in which we are trying to regiser vg224 its not getting autoregistered & if we add it manully it shows status a unknown
we are using SCCP . Is there is any document on configuration please guide us
regards
pushpak
Overall Rating: 3 (1 ratings)
pratik.rb Thu, 12/17/2009 - 08:57
You need the last 10 characters of the mac address of the VG224 VoIP interface.
Typically you will configure the VG224 as below:
stcapp
sccp local FastEthernet0/0
sccp ccm identifier 1 version
sccp ccm identifier 2 version
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
stcapp ccm-group 1
stcapp
dial-peer voice 200 pots
service stcapp
port 2/0
dial-peer voice 201 pots
service stcapp
port 2/1
dial-peer voice 202 pots
service stcapp
port 2/2
dial-peer voice 203 pots
service stcapp
port 2/3
dial-peer voice 204 pots
service stcapp
port 2/4
dial-peer voice 205 pots
service stcapp
port 2/5
dial-peer voice 206 pots
service stcapp
port 2/6
dial-peer voice 207 pots
service stcapp
port 2/7
dial-peer voice 208 pots
service stcapp
port 2/8
dial-peer voice 209 pots
service stcapp
port 2/9
dial-peer voice 210 pots
service stcapp
port 2/10
dial-peer voice 211 pots
service stcapp
port 2/11
dial-peer voice 212 pots
service stcapp
port 2/12
dial-peer voice 213 pots
service stcapp
port 2/13
dial-peer voice 214 pots
service stcapp
port 2/14
dial-peer voice 215 pots
service stcapp
port 2/15
dial-peer voice 216 pots
service stcapp
port 2/16
dial-peer voice 217 pots
service stcapp
port 2/17
dial-peer voice 218 pots
service stcapp
port 2/18
dial-peer voice 219 pots
service stcapp
port 2/19
dial-peer voice 220 pots
service stcapp
port 2/20
dial-peer voice 221 pots
service stcapp
port 2/21
dial-peer voice 222 pots
service stcapp
port 2/22
dial-peer voice 223 pots
service stcapp
port 2/23
Then take the MAC Address of the ethernet interface you connect to the network:
show interface fa0/0
Add the SCCP Gateway in CallManager. Goto Device > Gateway > Add new > Model of router > SCCP Gateway > Last 10 characters of mac in gateway as device name. Select the ports 24FXS SCCP
Then you can go ahead and configure the ports after which they will start getting registered.
You can see registered status from VG224 by typing "show sccp" - the port status should be "Cause Code - NONE"
pushpak.lele Thu, 12/17/2009 - 09:09
hi
thanks for help
in configuration
sccp
version of ccm its not showing 6.1 it shows only up to 5.0
we tried with latest ios for vg224 it shows the same
regards
pushpak
pratik.rb Thu, 12/17/2009 - 09:17
Thats fine. Just put version as 5.0. It will get registered..:)
Please rate helpful posts..
Tommer Catlin Thu, 12/17/2009 - 09:23
I can never get auto registration to work on the vg224.  Whats the trick?  because I want to use TAPS on it.
I can bulk load VG224s no problem.  But it would be alot easier to TAP the ports in.
pratik.rb Fri, 12/18/2009 - 00:32
I doubt whethere auto-registration is supported for the VG224 (atleast I know till ver5) I dont know if it has got supported on version 6 & 7.
There are some bugs relating to auto-configuration of VG224. You may check them out:
CSCtc90838
CSCsw43113
