How to determine DSP resources
Answered Question
Dec 17th, 2009
  • Bronze, 100 points or more
I have a question about DSP resources.
I understand that for SIP trunking, the maximum amount of concurrent calls on a given SIP trunk depends on the amount of availiable ro allocated DSP resources available to that sip trunk. Is that correct?
Also, how can I determine the amount of DSP resources my system has available to both SIP truunking and Ad-Hoc conferencing, etc... ?
I currently have an 8 user UC520 with Meetme and Multi-party conferencing enabled.
More detailed specs are available if need be.
Thanks.
-Brian
www.jaydien.com
Correct Answer by Marcos Hernandez about 7 years 5 months ago
Calls over a SIP trunk will invoke DSP resources only if made from a local FXS port, if transcoding is used, or if the SIP call joins a conference session.
Marcos
Overall Rating: 5 (1 ratings)
jaydien1358 Fri, 12/18/2009 - 05:57
Hi Marcos,
Thanks.
So if I've read this correctly, calls recieved or placed over a SIP trunk by IP phones do not take up any DSP resources? And does the processing of a SIP trunk itself, i.e. establishing and  maintaining the TRUNK, take up any DSP resources?
-Brian
Correct Answer
Marcos Hernandez Fri, 12/18/2009 - 06:00
  • Blue, 1500 points or more
Marcos
