Multiple Route-maps to define routes by Source IP
Mike Elliott
I have a very simple setup.  I have a cisco 837 that connects to a DSL line (via ethernet0) and I have Nat setup on that interface in an overload.  That interface also has a route-map applied to it so that it can divert some traffic based on an ACL to our vpn tunnel.
I recently got handed the task of having this branch office also test a new ISP.  The line is in, and I setup a secondary ip interface on ethernet0.  I'd like to route some machines through the new ISP while others go through the old one.
Is this possible?
11 Replies 11
Giuseppe Larosa
Hello Mike,
combining NAT and PBR you should be able to do this.
Use extended ACLs for NAT invoked inside a route-map.
The route-map needs to have two blocks one for NATTING and diverting hosts for new ISPs, the second block can represent the current NAT.
In this case I would use an ACL that denies traffic to vpn destinations and traffic sourced by the sample hosts that should use the new ISP.
Hope to help
Giuseppe
Thanks Giusular
Here is my route map and nat overload statements, very simple..
ip nat inside source route-map nonat interface Ethernet0 overload
route-map nonat permit 10
match ip address 110
Access list 110 contains the traffic from my Branch subnets, to my HQ Subnets.
Ethernet0 has two IP addresses and the crypto map attached to it. xxx.xxx.xxx.1 is my NEW isp, and yyy.yyy.yyy.1 is my OLD isp.
interface Ethernet0
description "Connected to the Net"
ip address xxx.xxx.xxx.1 255.255.255.240 secondary
ip address yyy.yyy.yyy.1 255.255.255.192
ip nat outside
no ip mroute-cache
half-duplex
crypto map test
interface FastEthernet0
description "Internal Lan"
ip address 192.168.3.254 255.255.255.0
ip nat inside
ip route-cache policy
ip policy route-map rock
no ip mroute-cache
speed auto
half-duplex
Route map rock sets the next hop for site to site traffic through the vpn tunnel.
route-map rock permit 10
match ip address 123
set ip next-hop 1.1.1.2
So if I can explain it a bit better, I want to have a decision made in one of those two maps, or in another nat pool to direct "some" traffic down the OLD ISP and the rest of the traffic out the NEW ISP.  I want to define the different routes based on the source and desination IP addresses.
i.e. all VPN traffic to go through the old isp, and all other traffic to go through the new one.
The default route is currently set to the OLD ISP.
Hello Mike,
an example is provided here
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1073518
in your case you need to use two statements like:
ip nat pool newISP
ip nat inside source route-map rock pool newISP overload
ip nat inside source route-map ISP1 interface eth0 overload
route-map rock is also invoked on internal LAN interface
the ACLs used in the two route-maps should clearly deny what is not to be natted by the current route-map
if for example first half of net 192.168.3.0/24 is to be used with old ISP
access-list 111 remark acl for ISP2
access-list 111 deny ip 192.168.3.0 0.0.0.255
access-list 111 permit ip 192.168.3.128 0.0.0.127 any
access-list 112 remark acl for ISP1
access-list 112 deny ip 192.168.3.0 0.0.0.255
access-list 112 permit ip 192.168.3.0 0.0.0.127 any
route-map ISP1 permit 10
match ip address 112
match ip address 111
Hope to help
Giuseppe
i just wanna add to the nice post from Giuseppe,  that you almost need to have the exit interface matched int e route map to avoid the nat using the first nat line only
route-map xx
match interface x/x
where x/x the interface that supposd to be the exit interface for that traffic ( only required with nat command )
good luck
if helpful rate
Could I test this out by setting up route maps for each isp like this:
route-map isp2 permit 10
match ip address 102
set ip next-hop
route-map isp1 permit 10
match ip address 101
set ip next-hop
Then use static nat translations pointing at the route-maps like this:
ip nat inside source static aaa.aaa.aaa.1 xxx.xxx.xxx.21 route-map isp2
ip nat inside source static aaa.aaa.aaa.2 yyy.yyy.yyy.21 route-map isp1
I am using static routes, so I could just set two static routes to 0.0.0.0 0.0.0.0
Hi Mik
all of the above will work
however to make you 100% sure just follow the bellow example
first you have to have two default routes each one point to one of your ISP's link
internal network
10.1.1.0/24 --- this go thorugh old ISP -- ISP1
20.1.1.0/24 -- this will use the new ISP-- ISP2
E0--To internal LAN
E1 ---to ISP1
E2 -- o ISP2
access-list 10 permit 10.1.1.0 0.0.0.255
access-list 20 permit 20.1.1.0 0.0.0.255
route-map PBR 10
match ip add 10
set ip next-hop ISP1
route-map PBR 20
match ip add 20
set ip next-hop ISP2
route-map IPS1 permit 10
match ip address 10
match interface E1
route-map ISP2 permit 20
match ip adress 20
match interface E2
interface Ethernet0
ip nat inside
ip policy route-map PBR   ---- this will do policy based routing for you ----
ip nat inside source route-map ISP1 interface E1 overload
ip nat inside source route-map ISP2 interface E2 overload
int E1
ip nat outside
int E2
ip nat outside
good luck
if helpful Rate
Hello Marwan,
only a small note:
Mike is going to use a single WAN interface with new ISP using secondary IP address for this reason I thought that using a NAT pool to represent the secondary address is more sure, that is when we use interface type x/y in NAT we are referring to primary address.
From this the little changes in my proposal.
Mike:
yes using static NAT you are in a match with the link I had provided in my second post in this thread.
Hope to help
Giuseppe
Hi Giuseppe
i think i hhavn't noticed this point
anyway still all the solutions provided in the discussion valid except as you mentioned inthe case of a scondary ip Mike needsto use a pool with overload option
thank you for you and good luck for Mike
Hi Mike
see this document which will give all the information and configurations steps
https://supportforums.cisco.com/docs/DOC-8313
good luck
Thanks for everyone's help so far, I do plan on rating all of your suggestions/recommendations when I get the plan implemented.
That being said, I have not been able to configure the router yet because my new ISP has thrown a bit of a monkey wrench into things.  They have provided me with a pre-confgured Cisco DPC3000 cable modem.
They have assigned me a CIDR block instead of giving me an IP Range like I am used to.  It appears, from their documentation I should be using xx.xxx.178.100 (seen below) as my wan interface, then using the CIDR block as my internal IP address range.  This simply won't do because we have a lot more machines inside our network than they block provisions for, and there are a lot of services in place that would be very difficult to re-work into the new address range.
Question here is, can I use this CIDR block on my 1710?  If so, what's the best way to implement it considering I want to have both ISPs up for a period of time in the transition phase?  I have been told by the ISP that it is impossible to set the WAN IP and the CIDR block on the external interface on the router.
My old isp gave me a range of 32 addresses, and a gateway to use as the default route from my router... simple enough. I set one of the range as my wan interface, use it as a nat overload IP, then I statically nat a bunch of internal machines to the outside world (hence my need for an IP Range).
The new ISP has given me this
For my wan Interface it's
IP: xx.xxx.178.100
Mask: 255.255.255.224
gateway: xx.xxx.178.65
For my CIDR Block
Subnet: xx.xxx.163.192/27
Gateway: xx.xxx.163.193
If I set xx.xxx.178.100 with the right mask as a secondary.  I try and ping the upstream router and get very sketchy results.  If I ping directly to the upstream router it fails.  If I use xx.xxx.178.100 as the source interface, I get a lot of timeouts but ocasionally I get a reply.  If I disconnect the router from the cable modem, and setup a workstation with the 178.100 address, I can ping the upstream router consistently.
Here is my config
interface Ethernet0
ip address xx.xxx.178.100 255.255.255.192 secondary
ip address yy.yy.89.66 255.255.255.192
ip nat outside
no ip mroute-cache
half-duplex
crypto map test
ip nat inside
no ip mroute-cache
speed auto
half-duplex
ip route 0.0.0.0 0.0.0.0 yy.yy.89.65
!route-map nonat is for vpn traffic
are using a switch between your router and ISP links
if yes
try the follwoing method
in your switch create a tunk lin to the port connected to it
in ur swtich create two vlan vlan 2 for ISP 1
and vlan 3 for ISP 2
put ISP 1 port in thre swtich int vlan 2
and isp port in the switch in vlan 3
in your router use subinterfaces instead of secondary ips
int ethernet0
no shut
ip nat outside
int ethernet 0.1
encapsulation do1q vlan 2
ip address x.x.x.x
p nat outside
int ethernet 0.2
encapsulation dot1q vlan 3
ip add y.y.y.y
ip nat outside
and use your normal nating config
good luck
