Multiple Site to Site Tunnels
Dec 17th, 2009
I have to setup a router with multiple site to site tunnels.  I already have one of the tunnels established.  The subnets at each branch office will NOT overlap.
I am using NAT Overload w/static nat translations, I have a route map to except vpn traffic from the nat process.
crypto map intmap 5 ipsec-isakmp
set peer <Branch Office A>
set transform-set trans1
match address 130
route-map rock permit 10
match ip address 123
set ip next-hop 1.1.1.2
route-map nonat permit 10
match ip address 110
How do I add a crypto map that will do Branch Office B?
Rick Morris Thu, 12/17/2009 - 12:52
  • Silver, 250 points or more
same as the first just increase the process number.  You have 5, use 10:
crypto map intmap 10 ipsec-isakmp
set peer
Mike Elliott Thu, 12/17/2009 - 12:56
Cool beans, that is what I thought.
Are there any caveats or best practices?  Should I expect to be able to route branch to branch traffic through the HQ? Or should I setup separate tunnels for that?
Rick Morris Thu, 12/17/2009 - 13:03
Honestly, the best set-up for what I think you are looking for is DMVPN.  http://www.cisco.com/en/US/products/ps6658/index.html
This allows you to build dynamic tunnels between offices without hair-pin routing via the Hub.  After the traffic stops between site to site it will tear the tunnel back down based on the timers you set-up.  This is accomplished via NHRP, with is a table that holds are next hops of all te tunnels.  So for instance site A wants to talk to site F.  Site A will send a look-up to the Hub asking for this info.  The hub will respond and site A and F will negotiate a tunnel.
