access-lists on layer 3 switch
Answered Question
Dec 17th, 2009
I am going to be installing some layer three switches. I have a question about how access-lists work in this enviornment.
Enviornment:
Single switch, uses VLAN 10. Host1 is connected to port 1 and host 2 is connected to port 2. both ports are access ports for vlan 10. can I put an acl on vlan 10 that prevents host1 from talking to host 2? In other words, does the traffic have to flow from one vlan to another for the switch to compare it against the acl?
I am pretty sure that the acl wouldn't affect the traffic, but I just want to make sure.
Ben
Correct Answer by Jon Marshall about 7 years 5 months ago
Enviornment:
Ben
Ben
An acl applied to the L3 SVI for vlan 10 would not affect traffic between hosts in the same vlan. If you want limit traffic between hosts in the same vlan then you need use a VACL (Vlan acl).
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 12/17/2009 - 16:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Enviornment:
Ben
Ben
Jon
Benjamin Waldon Thu, 12/17/2009 - 16:58
ooh very nice. thanks!
do you know of any white papers on virtual acls. I will do a search for it too, but if you have it handy, that would be great.
Does virtual ACLs require any specific licensing on the switch or a specific IOS version, etc?
Ben
Jon Marshall Thu, 12/17/2009 - 17:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ben
Ben
When you say virtual acls do you mean vlan acls ?
If so you can use the config guides for your relevant switch and there will be examples in their. Presumably you know how to find config docs for your switch ?
Jon
Jon Marshall Thu, 12/17/2009 - 17:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Ben
No problem. Forgot to answer last question. They should come as standard on your switch so no special license or specific IOS.
Jon
Related Content
