12-17-2009 06:50 PM - edited 03-06-2019 08:59 AM
I have an ESXi vmhost setup to trunk vlans 2, 100 and 101 to a 6509; vlan 2 is working, but neither 100 nor 101 come up. I can't see any reason for one to work and the others not --- the only difference is the vlan id. Native is the default vlan 1 and is not being used.
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2O3SV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
cisco WS-C6509 (R7000) processor (revision 3.0) with 227328K/34816K bytes of memory.
Processor board ID SAL0827BAAS
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
# sho run
interface GigabitEthernet5/1
switchport
switchport trunk allowed vlan 2,100-102
switchport mode trunk
interface GigabitEthernet5/6
switchport
switchport access vlan 101
switchport mode access
#sho int gi5/1 trunk
Port Mode Encapsulation Status Native vlan
Gi5/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi5/1 2,100-102
Port Vlans allowed and active in management domain
Gi5/1 2
Port Vlans in spanning tree forwarding state and not pruned
Gi5/1 2
#sho int gi5/1
GigabitEthernet5/1 is up, line protocol is up (connected)
#sho int gi5/6
GigabitEthernet5/6 is up, line protocol is up (connected)
#show int vlan 2
Vlan2 is up, line protocol is up
#show int vlan 101
Vlan101 is up, line protocol is down
Solved! Go to Solution.
12-17-2009 08:45 PM
Do show vlan to double check and if it doesn't exist, do the following
config t
vlan xxx
exit
and confirm it with show vlan
jerry
12-17-2009 07:17 PM
Hi Alan,
Usually this happens when you do not have spanning tree instance for that VLAN.
Can you do a:
sh spanning-tree vlan 100 or 102?
Reza
12-17-2009 08:42 PM
It's true, there's not, but that sounds like a chicken-egg problem. Though, actually, ESXi specifically doesn't do spanning tree because their virtual switches don't talk to each other, preventing loops (according to their docs). Also, vlan2 is working, and I would expect it to have the same problem as the other vlans.
I did try adding:
switchport nonegotiate
spanning-tree portfast trunk
12-17-2009 08:45 PM
config t
vlan xxx
exit
jerry
12-17-2009 09:15 PM
Progress! I had defined the interface to get an ip address for testing, but not the vlan itself:
Gi5/1 2,100-102
Gi5/1 2,101
Gi5/1 2,101
#sho vlan name VLAN0101
VLAN Name Status Ports
101 VLAN0101 active Gi3/7, Gi5/1, Gi5/6
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
101 enet 100101 1500 - - - - - 0 0
Remote SPAN VLAN
Disabled
Primary Secondary Type Ports
# sho run
interface Vlan101
description ServerNet NG
ip address 172.20.19.253 255.255.252.0
no ip redirects
hold-queue 2048 in
hold-queue 2048 out
12-18-2009 06:33 AM
Check your native VLAN under ESXi, i think vmware is using something like VLAN0 as native, don't remember that 100%.
jerry
12-18-2009 10:05 AM
I don't why the native vlan would matter (assuming it doesn't conflict with a tagged vlan), as I have all the virtual nics in tagged port groups (save for a management lan on a different physical interface).
12-18-2009 11:13 AM
I think VMware uses VLAN 0 for all untagged frames (native vlan) and I believe you have to configure service console port group with VLAN id 0.
