12-17-2009 09:20 PM - edited 03-04-2019 07:00 AM
Hi, I have DDC-WAN-R1 and Core switch. I have few static routes on Core switch which I have redistributed into EIGRP. DDC-WAN-R1 and Core switch is on EIGRGP too. My target is to modify local EX EIGRP distance on DDC-WAN-R1 which is getting D EX 172.28.20.0/24 from Core.
But my distance on DDC-WAN-R1 is still showing 170. Please help, i have pasted the conf of DDC-WAN-R1 below.
DDC-WAN-R1#sh run | begin router eigrp
router eigrp 1
network 0.0.0.0
distance 199 100.100.100.1 0.0.0.0 1
no auto-summary
access-list 1 permit 172.28.20.0
12-17-2009 11:25 PM
Hello Rupesh,
be aware that EIGRP has its own distance EIGRP command
distance eigrp internal-distance external-distance
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig1.html#wp1011683
Hope to help
Giuseppe
12-17-2009 11:28 PM
HI,
I do not want to change AD of all external EIGRP. I want to change only for 172.28.20.0. Please help how I can do it.
12-18-2009 04:41 PM
you can NOT change AD of
external eigrp route for spicific network/subnet not like the internal route
the only way to change external eigrp route is using the command mentioned above by other post
which will change the AD of all eigrp external route
hop this help
if helpful Rate
12-18-2009 06:41 PM
I agree you can not change the AD of external route using the distance command with ACL. That only works for internal routes. I even tried to see if specifying everyone as a the soure with ACL would work but no luck.
What are you trying to accomplish with the change of AD? Maybe there is another way that could be done with higher metric or distribute lists?
