WS-X6324-100FX-MM support in 12.2(33)SXH5
Dec 18th, 2009
I have upgraded a Supervisor 32 to software version 12.2(33)SXH5 and discovered that all the X6324-100FX-MM modules are unsupported. The software wont even power them on.
I have checked over the relase notes and it doesn't say anything about these modules being unsupported. It DOES state that the singlemode variant is no longer supported, that is, WS-X6324-100FX-SM. Have cisco forgotten to include the multimode version in the release notes or is there something else going on here ?
Chris.
cbeswick Fri, 12/18/2009 - 04:05
Nevermind I have just found that this has been resolved in SXH6!
