12-18-2009 05:09 AM
Dan / Tim
On the old NetPro site when you were in a sub-forum of a major category eg sub-forum = Lan Switching & Routing, major category = Network Infrastructure, you had the option to navigate to other subforums within the same major category. So from Lan Switching and Routing i could straight to Wan Routing and Switching without having to go back up to the major category.
This functionality is available on the new site but only within the overview tab. Personally speaking i work from the discussions tab and i'm guessing so do most of the regualr contributors. Would it be possible to have the links for sub-forums on the discussions tab so you can move easily between the sub-forums. As most regular contributors have specific areas of expertise i suspect this would be very useful for a lot of us. And could the link take you directly to the discussions tab of the relevant sub-forum rather than the overview tab.
It would be good to hear from others as well to see if they think it would be useful and also if they do indeed mainly use the discussions tab.
Jon
12-18-2009 06:00 AM
Hi Jon,
I mainly use the Discussions tab, because from there you can see all discussions (active, inactive) plus other information. The usages I have found for the Overview tab are:
a. quick view of what's going on (who responds to what)
b. when a thread becomes lengthy, I can jump to the last post from the link found in the Overview tab.
However, I use the Discussions tab more often as you do and sometimes feel the need for the feature you request. I have found 2 workarounds for this:
a. To use the 'History' feature on the top right of the page (you need to set Discussions tab as 'default tab' for each section for this to work)
b. Have multiple tabs open in my browser for each section I am interested in (this is actually faster)
Kind Regards,
Maria
Message was edited by: marikakis
12-18-2009 08:43 AM
Hey Jon,
Excellent idea for sure my friend! You have my vote
I am always in the "Discussions" tab as well so this would
improve the navigation.
Cheers!
Rob
12-18-2009 09:12 AM
Hi all,
I am with you on this one, but maybe there is a small problem. The Navigation on the left of the Overview tab seems to be a part of the whole Overview tab, and it fits there because not much else is included in this tab. If this Navigation part could somehow be moved/duplicated to the Discussions tab where exactly could it fit? The Discussions tab has a lot of information and at least I can't see very easily where exactly it should be placed. Maybe the box above Discussions could be squeezed a bit (mostly white/empty), so it can fit there or maybe the LeaderBoards could be pushed further down the Discussions tab. I don't know.
Kind Regards,
Maria
12-18-2009 10:18 AM
marikakis wrote:
Hi all,
Kind Regards,
Maria
Maria
Agreed that there is no obvious space to put it. It would need to be visible from the top of the page rather than have to scroll down i think. It could fit in the box above but there is also space down the right hand side - perhaps it could be put above the Leaderboards ?
I used to have multiple tabs open all the time on the old site but i kept getting locked out of NetPro and had to get Dan to unlock my account so i'm a bit wary of that
Rob made a really good point in that just removing having to go up to go back down again would speed things up.
Jon
12-18-2009 10:46 AM
Hey Jon,,
Thanks for opening up this thread (+5 buddy!)
The "lockout" issue is a symptom of overuse
Have a great weekend,
Cheers!
Rob
12-18-2009 11:03 AM
Hi Jon,
Thanks for being tactful enough to not say that 5 Communities in the 'History' is not enough for your broad expertise. It's enough for me and I am also not aware of the 'lockout' issue you are both referring to. I see that Jon is also active in the security sections, which reminds me a Networkers session I was listening to about CCIE exams. The speaker from cisco was advising the audience to not lock themselves out of the routers, and someone asked if this happens often. The speaker replied: "Yeah, it happens all the time. Especially in Security! Those guys lock themselves out all the time!"
Kind Regards,
Maria
12-18-2009 07:08 PM
Absolutly 100% agreed with Jon. I have been looking for a way to get from one sub-category to another without going back up to a major category just like the old Netpro, but have had no luck. As a mater of fact, I was just about to write about this issue when I saw Jon's post. Thanks Jon,
Cheers,
Reza
12-20-2009 04:14 AM
Hi all,
An idea came to me about how to overcome the problem of where to put the navigation assistance requested feature. As you may have seen, when you put your mouse over someone's avatar, a mouse over pop-up box appears with some summary information about person's profile. Also, at the top right of the site you can see the (New, Account, History, Browse) features. Maybe the navigation could be placed and occupy very small space within each major section by taking advantage of a combination of those two features (and simultaneous manual setting of Discussions tab as 'default tab' by each user that prefers the Discussions tab as default).
Kind Regards,
Maria
12-20-2009 12:09 PM
Hello Maria,
I looked at the page to see where possibly the navigation assistance feature could go. I think an area right across from the "Discursion" and "Filter by Tag Group" section which is right above rating, votes, views, replies tabs may be suitable place if there is enough room. I personally think this feature is more important then other sections like Action, Notification and Popular Discussions and those could be eliminated if there isn't enough room at the top.
Again, that is just my opinion
Reza
12-20-2009 02:04 PM
Kind Regards,
Maria
12-20-2009 06:52 PM
Hi Maria,
Correct me if I am wrong, but if you add a link like you proposed below
Cisco Support Community>NetPro>Network Infrastructure>WAN, Routing and Switching
When you are in one forum (WAN Routing and Switching) you still have to click on Network Infrastructure and then to another forum (LAN Routing and Switching), which would be no different then just clicking on Cisco Support Community and then to the other forum.
Would this be the case or I am missing some thing?
Reza
12-20-2009 11:20 PM
Hi Reza,
With 'mouse over' I don't mean clicking. You just position the cursor above the link and the box magically appears. If you move the cursor away, box disappears. The difference is that you only have to click on a link within the pop-up box, and you are not actually going back (only target page is actually loaded). That is only one click to go from the WAN to the LAN. Or were you guys expecting to go there without any clicks at all?
Kind Regards,
Maria
p.s. I didn't propose a new link. The link already exists on the page. I only proposed the additional mouse-over functionality for the link. You would still be able to click on it if you like (same way it happens with usernames). The advantage is that the design of the page doesn't have to change. The downside is any time needed for the pop-up box to appear, but that should be less than going back. In any case, let's see what Dan has to say on this one. In the historical thread about the new site he was saying that the widgets on the Overview tab can be manipulated very easily, but it's not so easy to add widgets to the other tabs.
12-21-2009 05:39 AM
Maria
Or were you guys expecting to go there without any clicks at all? - You mean that can be done !!!. If so it gets my vote
Jon
12-21-2009 05:42 AM
Also, I think the LeaderBoards are the advertising part of the site and I consider those the first candidate for movement. Even Jon who finds himself in many of those is willing to move them if that improves navigation for him (which shows how important his original request is for him).
On a more serious note, yes if moving the leaderboards down was the only way to get the additional navigation options then i would be very happy for this to happen. I like the idea of a popup as well but as you say Maria, probably best to see what Dan has to say.
Jon
