CUCM add gateway query
Answered Question
Dec 18th, 2009
I want to add a Cisco 888 gateway using MGCP in CUCM version 6.1.2.1124-1, this type of Gateway is not there to add, is there an update I can apply to CUCM to be make this Gateway available to do this?
Correct Answer by Brandon Buffin about 7 years 1 month ago
According to the following link, you need a minimum of 6.1(3), 7.0(2) or 7.1(3).
http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_458826.html
Hope this helps.
Brandon
Correct Answer by asandborgh about 7 years 1 month ago
Norm,
Found this in a SRST document - implies support starts at 6.13
SRST 880 is natively supported by CUCM 6.13 and 7.1
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs43spc.html
HTH,
Art
Overall Rating: 5 (2 ratings)
norm.trees Fri, 12/18/2009 - 08:32
Cheers for that, looks like I will need to upgrade to 6.1.3.
Your help is much appreciated!
N.
norm.trees Fri, 12/18/2009 - 08:33
Thanks for your help here, looks like I will need to upgrade to 6.1.3.
Much appreciated!
N.
